Hi, guys,
There is a Pioneer SA-510 (Blue Line series) here that I sold to someone and I got it back because he insisted on that
The reason was that he says it suddenly got a blown channel. The right channel is out.
When powered up, it clearly shows that it is blown. The VU meter does not show output either.
I checked inside for visual damage but couldn't find anything so far.
The thing that I did find is that fuse 3 is done for.
So before I go any further, I wanted to ask for your expertise on repairing this and ask for the next step.
My guess is that the next step could be checking the output transistors.
Can this be done with a MM meter, set in Ohm mode, black probe on the heat sink and the red one on the collector of the transistors?
And perhaps other components like diodes, but which ones
Have added the schematic to this message.
(Note: it is a EU model.)
Thanks,
Dan
