Hi guys I have this BR101 bridge here. It is definitely faulty, with about 9V going in to the rectifier I only get about 6.8V DC coming out of it (and the output voltage is unstable with load) and the bridge gets quite warm with less than 1 amp load. If I increase the input voltage, the output doesn't increase proportionally.
I was a bit puzzled how a bridge rectifier could fail in this sort of way and I was seeing some odd readings around the bridge in circuit with my dmm on diode mode so I pulled the device and tested it on the bench
Here is what I found - these are Forward Biased voltages@
AC1 to negative 0.552V
AC2 to negative 0.501V
AC1 to positive 0.511V
AC2 to positive 0.503V
All above reverse biased = OC
AC1 to AC2 are OC in both directions
All this looks OK apart from some misbalanced voltages on the AC1 and AC2
But here's the really odd one.... testing from bridge negative to bridge positive reads OC with black meter lead to bridge negative and 0.960V with red lead to bridge negative!
OK so it's faulty. No worries.
But I can't for the life of me figure out what is going on in there to produce those readings.
After all it's just four diodes in a bridge circuit.
I've seen faulty Bridges before - Short, Open, Burnt and Exploded. But never 'wierd'
Someone please enlighten me.
best regards
