Hi everyone,
I have an HP 54603B oscilloscope that has stopped working and I’m posting here because I see lots of success stories with repairing the 54600 series (unfortunately none of them seem to have the problem I’m having).
I was away for about 6 months and when I got back I found that it wouldn’t turn on. There was no display on the screen and the fan sounded like it was running slowly. It’s been sitting in one spot on my bench so there’s no chance it got dropped or had something fall in it. I followed the troubleshooting instructions in the manual, including building the dummy loads, and I’ve isolated the problem to the power supply. Under load, all the voltages are too low and they fluctuate up and down over a 2-3 second period. I also read a significant AC component:
+5.1V rail: 0.69V - 0.75V (and 0.46VAC)
+15.75 rail: 3.1V - 3.25V (and 1.2VAC)
-15.75rail : -3.73V to -3.9V (and 1.0VAC)
My meter also reads 20Hz on all three rails when set to frequency mode. This is all according to my Fluke DMM (I wish a could put a scope on it, but…).
There’s a chattering/buzzing noise coming from somewhere on the board (at first I thought it was the fan but I hear it even when that’s disconnected). It sounds like it could be at 20 Hz too.
I suspected the electrolytic capacitors - I had to desolder some to get an accurate reading but they’re all within spec except one that measures 25uF (in-circuit) when it should be 12uF. There is a bit of brown stuff on both sides of the board but I think it’s flux.
I’ve also measured the inductors on the DMM resistance setting. They show less than 1Ω of resistance as expected. The dual diodes I could get at seem ok too. Bridge rectifier output is 170VDC.
Short of measuring every component on the board, where should I go from here?
