Author Topic: Asus P2L97 dead due to failed power supply  (Read 2848 times)
Offline canadaboy25Topic starter
« on: July 27, 2016, 07:48:46 pm »
Hey guys, I have an old Pentium II Asus P2L97 motherboard that was killed by a failed power supply.  I believe that the power supply sent a spike along the 5v standby rail although I'm not certain.  This was my first ever PC so it means quite a lot to me.  When I plug a good power supply in, it immediately powers up and the fan spins.  I can hold the power button for a few seconds and it will turn off.  If I press the button again it will turn on.  I get no beeps from the speaker and nothing on the screen.  I am not sure if the graphics card is dead too but I am certain the board is because it always used to beep after it POSTed.  I know my memory is good because I have tried it in another computer.  I also replaced every electrolytic cap on the board just in case they had failed but that made no difference.
If anyone has any ideas I would love to hear them.  Thanks
« Last Edit: July 27, 2016, 07:55:13 pm by canadaboy25 »
canadaboy25
- Sometimes the light at the end of a tunnel is an on-coming train
Offline Raff
Re: Asus P2L97 dead due to failed power supply
« Reply #1 on: July 28, 2016, 03:08:19 am »
I usually start with a POST card similar to this one http://www.dx.com/p/pc-post-diagnostic-test-card-motherboard-analyzer-for-pci-4-digits-red-420029#.V5l2bmYkqUk
Better still if you can find one with external LED board as its often hard to see them if its inside a computer case.
You will then be able to tell if the CPU is getting clock and the BIOS is being accessed by the CPU at least.
I mostly use mine to help find shorted RAM as often the motherboard wont even beep or display anything with shorted RAM especially if it has on board video support.
Good luck.
Raff.
The following users thanked this post: Ijaz
Offline Stefan Payne
« Reply #2 on: July 28, 2016, 03:20:54 am »
1. What kind of Power Supply did you use? Can you post a picture of the unit?
2. How did it fail? Was the +5VSB rail still in spec and not like 12V or something like that?
3. What Power Supply do you use now?
There were some changes to the spec that can make newer, good PSUs to not work with oldish hardware -> Does your board need the -5V rail? Newer units only have a -12V rail.
« Reply #3 on: July 28, 2016, 04:27:43 am »
Good luck.
Raff.
Thanks I was thinking of doing this so I'll order one and report back once it's here.
I'm afraid that power supply was scavenged for parts long ago.  I still have the remains but I don't think that will do much for seeing what voltage it put out.  I'm pretty sure I was getting absolutely nothing out of it after it blew but I'm not sure.  I've posted pictues of the label and burnt portion of the power supply.
I posted a pic of the power supply I'm using now.  I know my board needs -5 volts because that voltage was for the ISA slots which I have and use for my sound card.  The new power supply also has a -5 volt white wire.
It sucks that I don't know the actual fault.   Maybe I can follow the traces on the power supply to see which line got burnt if need be.
canadaboy25
« Reply #4 on: July 28, 2016, 04:47:41 am »
Well, the good news is that it's a more or less decent quality PSU, at least it should be (CWT is around today and still make more or less good PSUs though their soldering isn't that good)
The bad news is that it looks like the PSU is rather old and uses the so called 2 transistor standby thingy. That means that if the right capacitor (one of the smaller ones) goes bad the +5VSB rail goes way out of spec and fries something connected to it.
So with this knowledge it's possible that everything connected to this rail is fried - like chipset and memory...
Offline Rasz
    • My random blog.
« Reply #5 on: July 28, 2016, 07:03:40 am »
take everything off the board and trace what is connected to standby rail, probably some linear reg
Offline Ijaz
  • Country: pk
« Reply #6 on: July 28, 2016, 07:18:08 am »
Didn't know any such thing exists, thank you for introduction.
« Reply #7 on: July 28, 2016, 12:56:20 pm »
Well, yeah, I think there are also such things for PCI express and some higher end boards (like the MSI A88X-G45 Gaming, wich was the most expansive FM2+ Board at the time for about 100€) also have such things onboard...
« Reply #8 on: July 28, 2016, 05:13:50 pm »
How could the memory be fried if it works in another PC?  If the chipset is fried putting a new one on the board wouldn't be too bad.
When you say take everything off, you mean desolder every single component?
Yep that's exactly right.  I have an old MSI motherboard and it has a external readout that fits into an unused PCI slot on the case and has 4 LED's which read out any faults.
canadaboy25
