Hi all,
I sent my ProArt Studiobook 16 OLED (H7600, 12th Gen Intel) to the local repair guys to have a very simple DC in port replaced. I sourced the part myself on accessoires-asus (french company) after struggling to find the right part in the UK. It looked completely the same to the installed part from what I can tell. Originally the only issue with the laptop was a bad / loose DC connection, and so the computer and battery acted completely normal aside from a very poor connection that would fail at certain angles. After the repair was completed I brought it home and used it for a while, problem solved, but soon realized the battery wasn't charging at all! although the battery notification was reading that it was plugged in and it evening display a time till fully charged display (clocking upward, with a sense of humour I suppose).
Slowly the battery was depleting with use and the charger did nothing. I tried starting it with the battery unplugged, no luck. I check battery connections as well, no luck. I have now sent it back to the repair guys and they are stumped and currently working on it. I'm doing the best I can to help out by posting here. The repair guys said there is voltage leaving the DC port, but I haven't seen this with my own eyes so who knows.
What could possibly be happening here? it is an entirely new problem compared to when I was using the laptop before. Could this be caused by a low quality DC port if that is even a thing? Or is it else where in the mother board. I saw some repair videos on different manufacturers devices (like hp) where the problem ended up being a shorted diode and a faulty EC chip. But again, no problem before the installation of this DC port. We are ordering another one currently to give it a try, but I am not sure that's the problem.
I am including an image of the component and the component on top of the faulty component prior to install. I do not have images after the install but can ask the repair shop for some if needed.
Please help!
