Author Topic: ATLAS PEAK LCR 40  (Read 3968 times)
Offline lionelkjhTopic starter
ATLAS PEAK LCR 40
« on: December 06, 2016, 06:49:12 pm »
Good evening; I am trying to calibrate my ATLAS PEAK LCR40; Someone would know the procedure to follow to calibrate it ??? Thank you for your help! :-+
Re: ATLAS PEAK LCR 40
« Reply #1 on: December 07, 2016, 06:33:14 pm »
sniff! :scared:
Offline stj
« Reply #2 on: December 07, 2016, 11:40:32 pm »
« Last Edit: December 07, 2016, 11:43:50 pm by stj »
« Reply #3 on: December 08, 2016, 11:27:30 am »
Hello; Yes, already contacted, but no answer: he must reserve the right to reply, it remains to send by post; But I do not care because the distance is great, and the loss or deterioration is inevitable! That's why I use this forum to help me ..... :scared:
Offline Ordinaryman1971
« Reply #4 on: December 10, 2016, 02:14:19 pm »
I found the manual for it, it's talking about the self test which is kind of self callibration, look it up, may be helpful.
« Reply #5 on: December 14, 2016, 04:57:58 pm »
Good evening; Thank you for the documentation. Too bad that nothing indicates how to calibrate it ..... |O
Offline Falkra
« Reply #6 on: December 14, 2016, 08:22:25 pm »
Hi, I have one, but I thnnk calibration is done within the firmware or a programmed chip.
If you open it, there are no adjustable components, but there (I think) is a 4 pin programming interface).
See pictures here (exposed PCB on both sides) :
http://www.mikrocontroller.net/topic/215095
Hires pictures :
http://www.mikrocontroller.net/attachment/106697/edt_PeakAtlasLCR40_6.jpg
http://www.mikrocontroller.net/attachment/106696/edt_PeakAtlasLCR40_4.jpg
« Last Edit: December 14, 2016, 08:24:05 pm by Falkra »
« Reply #7 on: December 15, 2016, 04:54:37 pm »
Thanks! :-+
