Electronics => Repair => Topic started by: lionelkjh on December 06, 2016, 06:49:12 pm
Good evening; I am trying to calibrate my ATLAS PEAK LCR40; Someone would know the procedure to follow to calibrate it ??? Thank you for your help! :-+
sniff! :scared:
did you contact the maker?
http://www.peakelec.co.uk/acatalog/lcr_support.html (http://www.peakelec.co.uk/acatalog/lcr_support.html)
Hello; Yes, already contacted, but no answer: he must reserve the right to reply, it remains to send by post; But I do not care because the distance is great, and the loss or deterioration is inevitable! That's why I use this forum to help me ..... :scared:
I found the manual for it, it's talking about the self test which is kind of self callibration, look it up, may be helpful.
Good evening; Thank you for the documentation. Too bad that nothing indicates how to calibrate it ..... |O
Hi, I have one, but I thnnk calibration is done within the firmware or a programmed chip.
If you open it, there are no adjustable components, but there (I think) is a 4 pin programming interface).
See pictures here (exposed PCB on both sides) :
http://www.mikrocontroller.net/topic/215095 (http://www.mikrocontroller.net/topic/215095)
Hires pictures :
http://www.mikrocontroller.net/attachment/106697/edt_PeakAtlasLCR40_6.jpg (http://www.mikrocontroller.net/attachment/106697/edt_PeakAtlasLCR40_6.jpg)
http://www.mikrocontroller.net/attachment/106696/edt_PeakAtlasLCR40_4.jpg (http://www.mikrocontroller.net/attachment/106696/edt_PeakAtlasLCR40_4.jpg)
Thanks! :-+
