My GW Instek GPS-3303C power supply malfunctioned after I returned from vacation.The supply has a "Load ON/OFF" button , when turn off, the output is disable.when turn on, it enable the output.
Now, the button is completely ineffective, after PSU power on,settings are all displayed as zero. Press the button, nothing happened.
But interestingly, after a random period of time(At least ten or more minutes), it will enable output for no reason, and at this point, the display of voltage and current will return to normal.But at this time, you still can no turn off the output. That "Load ON/OFF" button still doesn't work.
I try to find service manual or the schematic for GPS-3303,But it seems that developers have never published such a file.
If anyone has seen a similar problem, can you provide a clue?
If I use the wrong tense or tone with an offensive tone, I'm sorry that I'm just using poor online translation tool.
