I recently fixed a trash-find 22" HP monitor. Similar problem...The display wouldn't stay on. It turned out to be bad solder joints at the CCFL bulbs. It's worth checking, as it doesn't require any special tools or skills. By the way, the menu button may not respond if there is no display input signal.
