A number of suggestions.
1) If you only replaced the obviously bloated capacitors, there may be more capacitors that are bad, but require out of circuit testing with an ESR meter.
2) Ticking suggests the SMPS is trying to start, but can't because
a) the startup capacitor (generally 22uF to 47uF/25 to 50V) is bad due to high ESR
b) the SMPS IC is bad
c) there is something shorted on the secondary side like a diode
3) If you think your Fluke meter is not working properly, start a new thread and I will try to provide suggestions on what to check.
