Author Topic: ATX PSU repair  (Read 1247 times)
Offline HeyyyTopic starter
ATX PSU repair
« on: March 23, 2019, 05:25:20 pm »
I have an ATX 450w psu that has bad caps(the bigg 200v ones that probably form the half bridge together with the chocke). I have some spares but they are half the nominal value of the original ones.I put them and the psu seems to work fine but the ripple levveles are high :200mv high and switching transients are way higher.
I did the mesurements under slight load at bootup.Is this fix safe or i should relly struggle to find caps of the right value that fit? I don't think i'll push it beyond 200W.My other psu is a 500w model and uses 470u in series....what my new caps are.The old ones were a pair of 820u in series.
Output voltages seem to be in speck or 10mV out.
PS:The new caps are 200V each so the voltage rationg is ok.My concern is about the capacitance.
« Last Edit: March 23, 2019, 05:26:55 pm by Heyyy »
Offline url
  • Country: scotland
Re: ATX PSU repair
« Reply #1 on: March 23, 2019, 05:31:41 pm »
Hi
I think you have answered your own question - the ripple levels are high.
Plus - it should be repaired back to how it was designed... the correct caps must be around somewhere at the right price.
Re: ATX PSU repair
« Reply #2 on: March 23, 2019, 05:39:30 pm »
I have them.But they don't fit.The only form factor i found for their original value are short and too bulky.Does anyone know any tricks to make them fit?
Offline coromonadalix
Re: ATX PSU repair
« Reply #3 on: March 23, 2019, 08:46:54 pm »
I would not try to fit them if the size dont match .. my 2 cents
add longer leads to the caps ??
Re: ATX PSU repair
« Reply #4 on: March 23, 2019, 09:44:19 pm »
I'll try the leads method and use longer leads ,but it's really cramped in there.
Also ATX supplys what topology do they use?Since i saw 2 power switches and 2 caps + 1 chocke i belive it is a half bridge type?
This way i'll know more about what cap value does to the output characteristics.
Offline PKTKS
  • Country: br
Re: ATX PSU repair
« Reply #5 on: March 25, 2019, 05:14:00 pm »
Yes usually a half bridge  but  cheap models also use a switch
110/220 which short cuts the virtual ground to the bridge rectifier
making it considerable different from the usual half bridge split cap.
If you are using 110 mode you have a different layout on the split
cap half bridge virtual ground.
In other words the full bridge rectifier with split cap virtual ground
is valid only on 220 inputs. On 110 a by pass switch cuts that.
Not considering more expensive models w/ PFC supervisors....
Paul
