Hi EEV community!
I am currently working with the repair of a Laminex Minitoke laminator. As the title says this laminator its not sensing the temperature, overheating the resistance and finaly burning the thermal fuses.
The lamiantor has 2 heating elements each one of them with 3 inside components; the heating resistance, one 216C thermal fuse and one more component that i think is the heat sensor (i think is a thermistor but not sure, picture attached).
I started removing the "thermistor" from the heating element to measure it and see if it is working properly, the problem is that the "thermistor" has a weird behavior. I tried measuring the resistance with a multimeter, at room temperature this component has a resistance of 1.5 Ohm aprox, i started applying hot air with a heating gun to increase the component temperature and see if the resistance changes. The problem is when a measure the cables coming out of this component in one polarity the resistance increases as the component heats (normal of a PTC), but if a measure it in the opposite polarity the resistance decrease when the temperature increases but at one point it starts giving negative resistance.
The previous described behavior confused me and i came to this forum to seek for assistance. Does someone know what this component could be or if this behavior is normal?
Thank you in advance!
Greetings Diego.
