Author Topic: AUL Instruments TVM4 multimemeter  (Read 621 times)
Offline Neil BarlowTopic starter
« on: January 13, 2022, 04:31:01 pm »
Hi Folks,
Recently, I have acquired an AUL Instruments Model TVM4 transistorized voltmeter (probably ca. late 60's , early 70's). After fixing a few obvious problems, the device appears to be operating on most or all functions, but is quite out of correct calibration. I don't have a manual or schematic. Thus, I am unsure as to the function of the some the adjustments available on the circuit board. I may still have one or two undiscovered electronic problems on the board as well.
A search of the net has not turned up anything in the way of a manual, schematic, or cal procedure. Is there someone here who could point me in the right direction?
Thanks much!
Neil
