Author Topic: Avo Megger BM80/2 beeping and shows E44 on display.  (Read 551 times)
Offline PaceguyTopic starter
« on: July 29, 2024, 05:45:01 pm »
I have an Avo megger model BM80/2 that when powered up beeps and shows E44 on the display no matter what position the function switch is in.
I looked online to try to find the service manual with no luck. Help would be greatly appreciated. Thanks in advance.
Offline trobbins
Re: Avo Megger BM80/2 beeping and shows E44 on display.
« Reply #1 on: July 31, 2024, 12:39:46 am »
I have schematics for BM80-400 Mk2 - PM me.  I have progressed some repair of my BM81/2, that also showed an E44.  So far I had to replace an LM324 to recover a bad 2.5V reference line, and replace an LM339 to recover its nominal input node voltages, but BATTOK line is still pulled low when I think it should be nominally hi, so WIP but I last had this on the bench last year.
Ciao, Tim
The following users thanked this post: Paceguy
« Reply #2 on: July 31, 2024, 04:53:29 pm »
Thanks Trobbins, I will check that out.
