Author Topic: avometer 8 mk1 reads high  (Read 832 times)
Offline m3vuvTopic starter
« on: September 19, 2021, 12:56:01 pm »
hi all,i have an old avometer 8 mk1,came to me with the movement o/c,i replaced it with a good one along with the swamp resistor bobbin but it reads about %20 high on dc volts ranges,havent tested others yet,all the shunts test good compaired to a working one,tried moving the magnetic shint but still reads high,any ideas?
Re: avometer 8 mk1 reads high
« Reply #1 on: September 20, 2021, 10:42:13 pm »
i am very suprised no answers yet,maybe this is before everyones time?
Offline George Edmonds
« Reply #2 on: September 21, 2021, 01:40:10 am »
Hi
The first step is to verify the 50 micro amp range preferably with another meter in series acting as a check meter.
George G6HIG Dover UK
« Reply #3 on: September 21, 2021, 03:28:43 pm »
i have done that,it checks out fine,ive also swaped the swamp resistor with a known good one,are the mk 1 and 2 the same electricaly?,if so i have a good mk2 that i can use to compair the shunts on the mk1 against.
« Reply #4 on: September 21, 2021, 04:28:42 pm »
I have tried to send you the AVO repair information without success
PM me with an address that I can send it to
« Reply #5 on: September 27, 2021, 02:18:07 am »
i have found resistors 2,3,and 4 o/c on the lower resistance board,can these be replaced with normal metal film resistors and 10 turn trimpots?,if i cant sort it it will get turned into an esr meter,like mt old braddley.
