Imgur seems to work
Here is the disparity between the Left and Right channels of the equalizer during a frequency response test by a HP35660A (identical signal and amplitude fed to both channels):
Thank you FloobyDust!
I found this guy on Ebay in Arizona selling the proper package type needed of the LM837. They are supposedly NOS National parts. I bought his last four.
I also swapped all Polyester caps with PP caps a few weeks ago. Some of the electrolytics were replaced with film of the values that I could find/fit.
*I also forgot to mention that the equalizer section only covers the low frequencies going to the sub-woofers. The internal cross-over module limits it even further since it's set at 75Hz.
The Sub-Sonic/Rumble/Cross-over graphs are perfect as long as the EQ isn't activated. I spent a lot of time in those other areas to make that happen. The EQ section is the last portion to deal with and I want it as good as I can get it. But remember, it's just the lower frequencies that are affected. Everything above 75Hz will be passed through to separate mono amplifiers un-touched. So the sliders for 90Hz and 125Hz will probably be set close to the "flat" position.
The signals below 75Hz are sent to a large integrated stereo amplifier dedicated to the L & R sub-woofers.
