Hello,
I (perhaps mistakenly) bought a broken 53131A with a dead PSU. Seller said it had the oven option - it didn't. Seller said it hadn't been opened - the power supply board hadn't even been screwed back in and it rattled when it got to me.
Worse there are parts missing off the PSU.
It is one of the Delta SMP-43DL units (different to the ones I have seen here on the forum). Same as this one but stuffed if I am paying that for it.
http://www.ebay.com/itm/0950-2139-SMP-43DL-Power-Supply-T61610-/361530977124?hash=item542ceceb64Anyway the tricky part is the main switching MOSFET is missing (it appears to have exploded).
The bulk capacitors seem to have been replaced with 47uF 250V units. 47uF seems too low and 250V is definitely too low (might have gotten away with that in the USA but not here in Australia).
Finally there is a zener diode ZD1 right near the switcher heat-sink that is gone.
It doesn't match the schematics for the 531XX PSU previously posted - it doesn't have the controller chip for starters.
Does anybody have one of these they could take a peak at for me? Or better a schematic.
Tom
