I have an LCD monitor that works...for about 1 second. That is:
1. Power on
2. It takes a second or two to boot (I guess that's what it's doing?)
3. It displays the correct image for 1 second
4. Backlight turns off again, but the LCD panel still works if you look at it closely with a flashlight
5. Power-cycle (soft or hard) to repeat from #1
It's supposed to have more dynamic contrast than the panel itself provides, and sure enough, the power supply PCB calls out both an ON/OFF and a DIM signal between the video processor board and the CCFL inverter. There's also a PID signal, that seems to be a constant 1.8V in all cases, plus some 60kHz noise when the backlight is on, so I have no idea what that does. Since all the buttons go to the video processor, I figured that the (intentional) inverter control is limited to those 3 signals, so I focused my efforts there to start with.
I really don't care about dynamic contrast for this application, so I'd be okay with just jerry-rigging it "ON" if necessary. If all of the original functionality can be kept, that's just a bonus.
I've completely replaced a CCFL backlight before, with LED strip lights (and cut the jumper that used to power that inverter, seeing that it was completely independent unlike this one, and wouldn't be missed), but since the tubes are clearly okay in this one, I'd rather not take apart the display module itself to get to them.
Here's a 1min video showing my reverse-engineered schematic, and analog 'scope captures (with my phone on a tripod) of the 3 signals between the video processor and the inverter:
Copy/pasted description:
The backlight comes on for about 1 second when the monitor turns on, then the backlight goes out again. Power-cycling (soft or hard, it doesn't matter in this case) gets the backlight back for another 1 second, ad-infinitum. The loud clicks in this video are from the soft power button, amplified by a lot, and the ambient noise removed.
I reverse-engineered the single-sided, through-hole PCB to get the schematic shown here, and then probed the interesting signals. The high-frequency, low(ish)-amplitude artifacts when the Backlight is ON, are about 60kHz. I didn't think to capture that explicitly, but pausing on the right frame shows about 3 cycles in 50us. That's the switching frequency of the CCFL inverter, so I'm guessing it has some parasitic coupling from there.
The 15-pin Controller (CN5), is a surface-mount PCB at 90deg to the main board, using a pin header to connect them as if it were another through-hole component. I didn't look very closely at that board.
