Author Topic: What does "jumping out" a circuit mean?  (Read 3994 times)
Offline komatsuTopic starter
« on: January 31, 2015, 12:03:41 am »
I've often heard the phrase "jumping out a circuit" in electronics - but what does it mean?
Online IanB
Re: What does "jumping out" a circuit mean?
« Reply #1 on: January 31, 2015, 12:05:17 am »
I think it is actually "jumpering out a circuit"; that is to say using "jumpers" or link wires to bypass a bit of a circuit or to change its configuration.
« Reply #2 on: January 31, 2015, 12:06:57 am »
You're right it is "jumpering out a circuit"
Online IanB
« Reply #3 on: January 31, 2015, 12:15:33 am »
FYI, a "jumper" is so named because it can jump across a gap, or jump from one place to another.
« Reply #4 on: January 31, 2015, 12:18:25 am »
Sometimes equipment can be powered by other means and a removable jumper is there for this purpose.
« Reply #5 on: January 31, 2015, 12:26:44 am »
On a damaged board, when would "jumpering out" be use? examples?
« Reply #6 on: January 31, 2015, 12:33:08 am »
For an external PSU.
Output stages to an external amp for example.
Damaged? One would need to know what part if the circuit was damaged.
« Reply #7 on: January 31, 2015, 12:56:12 am »
tautech, if for example diodes were damaged?
« Reply #8 on: January 31, 2015, 10:19:09 am »
More info needed.
Post a schematic or photo and more explanation of what you are trying to do?
Offline kolbep
    • ShoutingElectronics.com
« Reply #9 on: January 31, 2015, 10:50:14 am »
Sometimes if you put caps or led's backwards, they literally Jump Out of the circuit  :-DD Still haven't found some of them...
www.ShoutingElectronics.com Don't just talk about Electronics, SHOUT ABOUT IT! Electronics Blog Site and Youtube Channel
