Author Topic: Tektronix 2432A noisy trace  (Read 416 times)
Offline gerdyTopic starter
« on: February 23, 2023, 07:16:29 pm »
Hi, I have a Tek 2432A scope. It works well except it has a bit of a noisy trace. Grounding the input channel(s) does not change that, still noisy.
Anyone experienced this before? Any clues where I have to look to fix this?
Offline Ground_Loop
Re: Tektronix 2432A noisy trace
« Reply #1 on: February 23, 2023, 11:52:41 pm »
That actually looks kinda normal.  Go down to 2mV and check it.  I have a 2430 and a 2440 and they both pretty much do the same.
There's no point getting old if you don't have stories.
Offline David Hess
  • DavidH
« Reply #2 on: February 24, 2023, 10:54:56 pm »
Didn't we just cover this?
The Tektronix 2400 series DSOs are pretty noisy because of their CCD technology, but that looks pretty normal to me, and is actually not bad for a 300 MHz bandwidth, but check at the most sensitive vertical sensitivity to make sure.
