The HP 403B vintage transistor AC voltmeter may not be alone in using internal NiCad battery modules which need replacement over the decades. I just restored a 403B by replacing the 4x 6.5V 225mAh NiCad modules with four 6.0V active TL431 shunt regulators in series. An external battery can be connected if needed, such as 2x 12V 4Ah monoblocs. Maintaining internal batteries is always a pain, especially if the meter is only used intermittently. This meter only uses <10mA rail feeds, so the TL431 provides a nice quiet low impedance voltage reference to emulate a battery module.
The 403B may be vintage and only average responding, but it does have a 1-2MHz bandwidth so can be convenient to keep an eye on performance when other DMM's would not show a reading.
It does seem to have a display face that cracks and peels and can restrict needle movement, and the e-caps need replacing, but otherwise is pretty simple to work on. My meter movement has points of stiction, which seems to result from bearing slop (which I can't see how to repair), so that may be a show-stopper for some.
