Author Topic: Commodore C128D Power Supply - Capacitor Issue  (Read 6426 times)
Offline Chris2027Topic starter
« on: March 02, 2024, 10:02:06 am »
Hi all!!
Okay so I recently began work on my old C128D which had no power.  I'm not a fan of working with power supplies due to the high voltage in.
The PSU has 2 transformers and 3 outputs
  • 9v AC
  • +5v DC
  • +12v DC
After taking out the PSU, I found the 12v dc (yellow wire) was shorting to ground.  After removing a few things I finally removed a capacitor which alleviated the short.
The bad capacitor has the following written on it:
470 /16
FRAKO
S 9
So I took that to mean it is a 470uf 16V.
I put in an Electrolytic replacement, which physically is much smaller (but I assumed this is just because newer components are smaller), and wired up the PSU to the switch.
It looked good, the fan started up (Note: the Fan is on the +12v rail) and I was happy for about 5 seconds then a huge bang happened.  I've taken a photo of the caps.  The newly installed cap exploded!!
So my question is that did I install a capacitor that was too weak?  Did I misunderstand the writing on the old cap?  Could something else cause the cap to blow up, which may have also caused the old one to fail too?
In the screenshot the gold cap (left) is the original one, which is shorted (I have also tested on the cap itself, and confirm its definitely shorted).
The black cap (bottom right) is what I had replaced it with, and the other (top right) is the exploded cap,  It was the same as the black one.
Any ideas?
« Last Edit: March 02, 2024, 10:41:04 am by Chris2027 »
Offline eurgenca
  • Country: si
Re: Commodore C128D Power Supply - Capacitor Issue
« Reply #1 on: March 02, 2024, 10:50:35 am »
On the old cap, you have marked + on the new one you have marked - pole. Do you know this? If yes, check bridge rectifier.
The following users thanked this post: Chris2027
« Reply #2 on: March 02, 2024, 11:27:56 am »
Well I built up the courage to give it another go.. maybe I did put it in backwards??
I double checked the orientation, and this time I connected the output to the C128's mainboard.  This time the power is staying on and no explosion yet.  Maybe it needed to be connected before switching it on?
Chances are the fact that that the only capacitor that I replaced was the one to blow up most likely points to me being an idiot and installing it backwards
Anyway just going over it again seemed to help so thank you for taking the time to respond!
Offline agent_power
« Reply #3 on: March 02, 2024, 09:49:46 pm »
If there's IEC power inlet filter can, remove it. Those tend to blow up and stink
Offline pienari
« Reply #4 on: March 03, 2024, 07:02:31 pm »
I still wondering why to chance bad quality caps ?.
Waist of time.
Offline janoc
« Reply #5 on: March 03, 2024, 07:57:53 pm »
Given the explosion and the fact that the fan has powered up my bet is that you have, indeed, soldered the capacitor in backwards.
Electrolytic caps don't blow up like that unless (very) hot or connected in the wrong polarity (which makes them hot).
