I recently aquired an old KS-8455 volt/ohm meter used for telco cable testing. It appears in excellent working condition minus I do not have the proper 45 volt battery to power it normally. The Eveready No. 455, NEDA 201, 45 Volt is available but pricey. Would there be any drawbacks to using a step-up boost dc to dc module that has ability to go up to the 45v or close. I know switching frequency is very high but imput impedance of this meter is 430 ohms. Would needle deflection even be suceptable to that fast of frequency if boost module is used?
