As a test equipment addict, I own a pretty reasonable collection of TV/CATV/SAT field meters. I doubt there are many people with a bigger collection, but then, Youtube has taught me that there is always someone who does it faster, quicker, crazier, etc.
Anyway, one of the problems I have is that many of my portable test equipment units work with battery packs and those tend to age, even if you don't use them. Also, not charging them regularily (guilty) has a bad effect on them.
For years I have looked at how 18650 cells are used for these battery packs and Chinese seller offer spot soldering machines for 100-200 Euro. You then need the metal stripes to connect the cells and the cells - lots of them.
Now my questions are:
- The spot welder devices come with an alert that you need so many amperes on your houses switchboard. Is that really problematic? How much power is needed?
- How dangerous is it to handle the 18650 cells and trying to spot solder them?
- Where to get them at a reasonable price?
While I would like to keep all instruments in prestine conditions with full capacity battery packs, the truth is that I seldomly use them and when I do, it is on my desk where I can attach the power source.
It seems that the DIY approach to renew battery packs is still quite costly, considering that the average battery pack uses at least 12 cells if not much more.
Also, with new EU import laws and taxes, I don't know if the 18650 cells can be sourced cheaply.
And yes, I know that the battery pack is normally as good as the worst of the cells. Often you only need to replace a few to get almost full capacity back again.
Still I wonder, if it is worth it, especially considering the switchboard requirement and the possible danger hazards.
Your opinions please.
Regards,
Vitor
