My Amazfit Bip battery bulged enough to pop the front off, so I got a replacement and fitted that. But now it doesn't work - I presume I shorted something. Well, there is something shorted and I guess it was me, but that's all I know. The result is a component that comprises mostly charcoal.
The circuit below shows the relevant part. The battery is a Li-ion but there is a control or management board attached to the terminals. That supplies a connector which, for simplicity, I've shown as the battery. There is a cap, the ex-component and then another cap before the supply goes off around the watch.
My question is, what should the ex-component be? I am guessing a resistor or inductor, and I can't see that a resistor would make sense here so it is probably an inductor. If so, one would be used either for EMC or smoothing, and since this is all internal it's probably smoothing. Since it's 0201 (or was), would a bit of wire likely prove to be OK?
