Author Topic: BD636 replacement ? alternative ?  (Read 423 times)
Offline OverspeedTopic starter
« on: October 10, 2024, 09:15:33 am »
Hello
I have circuit with  PNP BD636 which is ? non available
maximum current collector is 1 Amp
load voltage Vceo is 12 Volt
frequency 500 kHz
best is a TO220 foot print
any idea in commonly available transistor ? TIP32 perhaps
Regards
« Last Edit: October 10, 2024, 09:25:59 am by Overspeed »
Offline coromonadalix
The following users thanked this post: BILLPOD
Re: BD636 replacement ? alternative ?
« Reply #2 on: October 14, 2024, 11:52:15 am »
you have a search tool
https://alltransistors.com/crsearch.php?mat=Si&struct=PNP&pc=30&ucb=60&uce=60&ueb=5&ic=3&tj=185&ft=3&hfe=25&caps=TO220&cf=on
check the results
Hello
Thanks
OK , but all resistor listed are  obsolete transistors  , Mouser ''alternative'' is a better tool as components are available , base on data of the BD636 .
Regards
OS
« Reply #3 on: October 14, 2024, 02:47:52 pm »
