Author Topic: Beatspill loudspeakers sytem not charging  (Read 600 times)
Offline CornboatsTopic starter
« on: June 02, 2020, 04:17:06 pm »
[ Specified attachment is not available ]Trying to troubleshoot this system. Batteries aren't charging -no charge light indicator on when plugged into usb.
Usb is 5v but when connected .6v across + & - at Beatspill end.
I removed the micro usb socket as I thouught this was faulty- hared wired connections by following the traces. Theres only 4 out of the 6 pins being used.
Could be the batteries are dead and pulling down the voltage but I don't know enough to know for sure. How do I rule out batteries without buying a new pair?
« Last Edit: June 03, 2020, 04:12:46 pm by Cornboats »
Offline floobydust
Re: Beatspill loudspeakers sytem not charging
« Reply #1 on: June 03, 2020, 11:02:06 pm »
Beatspills are notorious for breaking at the micro-USB connector, shearing it right off the PC board.
Or, the daughter board cracks the solder joints to the main board (under the green glue). It's a terrible design and fragile.
When it is plugged in to a charger, you should be able to measure 5V underneath at the main board connection, the 4-pins.
If the micro-USB has sheared off traces and lifted them, too hard to fix. Instead people are selling Beatspill replacement USB connector boards. I did a PCB layout a long time ago and I think it's an oddball thickness laminate so I left it.
« Reply #2 on: June 04, 2020, 08:03:52 am »
Thanks for the reply. Your usb board is exactly the same as mine except yours has diodes D300 & D301 missing & link L300 missing. On mine the 2 middle traces of the usb socket go to left side of D300 and right side of D301. I wondered if I'd got these connected the wrong way round and that was causing the low voltage.
I did hot wire the + & - direct to my 4.5v voltage regulator but as well as the voltage across + & - being less than 1v at the pcb end, the component marked as U7 which googles as a voltage booster converter was getting really hot. As the charging led wasn't showing I decided this wasn't the way to go.
Offline mikerj
« Reply #3 on: June 04, 2020, 09:11:57 am »
Check for internally shorted MLCC caps, seen this on a couple of different brand bluetooth speakers.
« Reply #4 on: June 04, 2020, 02:53:12 pm »
Thanks for your reply- I'll check and also solder pins previously suggested and come back with results.
Much appreciated.
Offline floobydust
« Reply #5 on: June 04, 2020, 05:37:22 pm »
U7 on mine is a TPS61175 boost-converter. Note there are also quite a few Beatspill firmware updates.
