Author Topic: Beeprog programmer - original - problem - eeprom error #0100, and next problems  (Read 2398 times)
Offline kaldach79Topic starter
I have a problem with my original Beeprog programmer.
Unfortunately its manufacturer support time has expired.
Programmer is correctly detected, but when I run selftest, he returns a error.
Self test log:
Communication test ............ OK                         0:00:00.1
L0148: RAM test ...................... OK                         0:00:00.5
L0149: EEPROM test ................... ERROR: #0100H.
L0150:
L0151:
L0153: Identification (X-Y-Z-R-IEC-D-SW): 165-0-0-0-0-23-3.32b/05.2017
This problem looks like eeprom damage. I wonder how to solve it and it is disappointing that the manufacturer does not support this model.
Can  Anyone help? :)
« Last Edit: March 08, 2021, 10:18:15 pm by kaldach79 »
Offline mon2
Re: Beeprog programmer - original - problem - eeprom error #0100
« Reply #2 on: March 06, 2021, 11:53:26 am »
Thank You for this link and solution :)
But I have two problem with this:
1. Zip file is password protected, and i don't have an account on this portal, and i can`t send PW question about password
2. I`m afraid when I`m programming PIC this firmware, and eeprom`s this dump`s the serial number will be changed, and my geniuine Beeprog will become a clone...
Best regards!
Offline coromonadalix
« Reply #3 on: March 06, 2021, 09:30:49 pm »
here ya go    i'm a member there
remove the  dot  txt extension, its a rar file
normally some beeprog need a test socket to validate the functionality
« Last Edit: March 06, 2021, 09:33:10 pm by coromonadalix »
The following users thanked this post: kaldach79
« Reply #4 on: March 06, 2021, 09:38:57 pm »
and the mhh thread point to another
https://mhhauto.com/Thread-How-to-repair-beeprog-clone?pid=991390&highlight=beeprog#pid991390
Beeprog_recovery_working.rar
 this is the file you  said it was password protected ?
« Reply #5 on: March 06, 2021, 09:52:32 pm »
Thank You!,
II'll try to repair it with these files :)
« Reply #6 on: March 06, 2021, 10:01:20 pm »
i asked the pw   .... have to wait
« Reply #7 on: March 06, 2021, 10:14:21 pm »
I have a dedicate test board for this programmer (the manufacturer supplies this) :)
« Reply #8 on: March 06, 2021, 10:29:48 pm »
found this on another website i'm registred with
remove the dot and txt extension, its a zipped file,  no pw
Damn they added many eeproms in it,  seeing the photos ??
Elnec is the main brand :  Dataman, Chipmaster  and others brandings are OEM's (ODM)  of Elnec
« Last Edit: March 06, 2021, 11:06:18 pm by coromonadalix »
« Reply #9 on: March 06, 2021, 10:41:51 pm »
Thank you very much! I appreciate your commitment to help :)
« Reply #10 on: March 06, 2021, 11:06:01 pm »
oooh kay   done some googlefuu
Well  past the v2.67   there is serial numbering detection, if the serial number is blacklisted it will bust your elnec beeprog programmer, there was many fake / cloned beeprog around
Elnec did this to protect their products
The serial numbers are encrypted in the ic's, and the ic's could not be read unless paying $$$ to break them, apparently someone did this, and sold some new serial programmed ic's
link for the v2.67 software   use at your own risk
https://mega.nz/file/99VDyIIb#2vjBcw69x69mcwuL_crZ1c7qR4KJ-ekRPvcIs7cscGM
« Last Edit: March 06, 2021, 11:10:30 pm by coromonadalix »
« Reply #11 on: March 08, 2021, 10:17:35 pm »
After reprogramming eeprom error #0100 is gone, however, this is not the end of the problems...
Self test detects another error #020DH: Supplies and DAC test...
When I try test of pins of the programmed circuit it ends correctly, but when I try read/write chip programmer display a error:
Error #6 (1/5000/7185/12085)
Unexpected error 1 [IEC:7, D:26]!
When I try make calibrate programmer there is no voltage on any of the pins of the socket ( i used dedicate test board).
But when i try read chip then I see the short pulses on the oscilloscope.
Perhaps some of you had a similar problem?
I am constantly trying to find the cause of the fault. I will write if I find something.
