Hello, I was recently asked to look at an issue with an automatic gate opener. This system operates a gate to block a private road from public access. The system is hard wired to 120VAC but this feeds a transformer and internally it uses 24VDC and has a small 6Ah battery bank which will open the gate as a fail-safe during power outages.
The problem is the batteries keep being severely discharged and then do not work when there's a power failure.
2 weeks ago I replaced 1 year old batteries that were fully charged and now they are already discharged. The two 12V (in series) batteries I replaced had been discharged to 6.8 and 9V respectively!
There have not been any power outages so the batteries shouldn't have even been loaded (other than two power failure tests I did after installing them).
The system is supposed to keep these batteries charged automatically, and while the "charging" LED is lit on the large PCB, suggesting it is charging, I'm only showing 20V DC on the terminal where the battery gets connected (lower left in photo).
I am in the process of replacing some older wiring and corroded connections and blowing out the system, since you can see it's dirty with spider webs and such, but unless its as simple as an issue with voltage leaking due to nasty conditions, I'm not sure what to consider from a component perspective.
As may be obvious, I have a limited knowledge of electronics but am trying to learn and would like to try to figure this out. Do you have any suspicions of components I might look at first?
