Author Topic: Beginner Question - Repair of 8.4v lithium battery PCB  (Read 2046 times)
Offline brookoTopic starter
« on: February 05, 2024, 06:07:44 pm »
Hello, I have removed the PCB from a lithium battery used to power cycle lights. 8.4v 18650 8cells
I believe that the PCB is damaged as the lights on the power source won't stay on, but will for other battery packs.
Can anyone advise how I check the PCB please. The equipment I have is...
Bench power
UNI-T volts, amps and resistance meter
Pic attached
Thanks, Andy
Online tunk
  • Country: no
Re: Beginner Question - Repair of 8.4v lithium battery PCB
« Reply #1 on: February 05, 2024, 06:10:35 pm »
Could be an BMS. Any markings on the ICs?
Edit: What's the voltage of the two cells?
« Last Edit: February 05, 2024, 06:12:37 pm by tunk »
The following users thanked this post: brooko
« Reply #2 on: February 05, 2024, 06:31:59 pm »
Hi, thanks for looking at this.
The chip has 8205A Y105220F on it. The batteries are putting out 7.4v.
Andy
« Reply #3 on: February 05, 2024, 07:00:41 pm »
Could be the one cell is failing, and thus the pack shuts off. Put it in, and run till it cuts off, and measure each cell block voltage. Likely one will be just under 3V when the BMS cuts off the pack.
