Author Topic: JBC AM station repair help - 2UA  (Read 1505 times)
Offline bufalo88Topic starter
« on: January 30, 2024, 09:55:38 am »
Dear friends and colleagues of the forum, I ask you for help in trying to repair this station, it presents the following error on the display
"attention sensor temperature error; and the desoldering iron turns on fire. The hot air works. I thank those who want to participate.
If anyone has the wiring diagram it would be appreciated, I'll add some photos
Ps. I apologize for the English but I use google translator
Re: JBC AM station repair help - 2UA
« Reply #1 on: January 30, 2024, 10:05:56 am »
From the card you can see that several components are missing that concern the channel dedicated to the DR5650, I tested the four mosfets and they were good
Offline Hydrawerk
« Reply #2 on: January 30, 2024, 07:27:57 pm »
Do you have another handle like a T245? https://www.jbctools.com/t245-handles.html
Did you try it?
There are probably two channels on the JBC AM. Do both channels do the same error?
Offline Hydrawerk
« Reply #3 on: January 30, 2024, 07:31:29 pm »
I am not sure if an user manual helps you but here it is anyway.
« Reply #4 on: January 31, 2024, 11:52:38 am »
Hydrawerk thanks for the answer yes the station has two channels one for c245 and the other for the dr 5650 unfortunately the station is stuck on temp sensor error and doesn't even work with the c245 stylus.
Can you help me? I have disassembled many components to test them but I can't find the faulty ones
Offline uli12us
« Reply #5 on: January 31, 2024, 12:08:34 pm »
Have you tested the connections, Plugs from the iron to the PCB as well?
« Reply #6 on: January 31, 2024, 02:28:24 pm »
Yes, I have tested them, the fault is definitely on the main, you have the opportunity to give me further ideas.
I would like to read the microprocessor to see how it handles errors.
any form of help is certainly welcome
