Electronics => Repair => Topic started by: andybarrett1 on January 18, 2018, 04:15:39 pm
Hi
Thank you for reading... Can any body help me with the schematic or help ID this Chip (IC1)
I want it to be a op-amp but really not sure
BR
Andy
Most likely a quad op-amp - would need to see more of the surrounding circuit to be sure:
http://www.st.com/resource/en/datasheet/tl064.pdf (http://www.st.com/resource/en/datasheet/tl064.pdf)
It is a TL064C (http://www.st.com/resource/en/datasheet/tl064.pdf) made by ST, quad op-amp.
Behringer stuff is pretty cheap inside, the electrolytic capacitors are very low quality and cause problems. First thing I check.
Hi All
TL064C
I can see it now...... Thank you for replies.
BR
Andy
Sorry for off topic but just curious, which brand (preferably not overpriced) would you recommend for guitar effects, that is known for decent quality components?
Hi
From a repair point of view all the pedals I have seen are a much of a muchness .... Hand wired EFX and Amps are an exception !
BR
Andy
