It would say it's N.O. as they are low cost and very common. No need for N.C. here.
The only thing to be careful of is orientation, the flat leafs are in the same place i.e. if you put the reed switch in rotated 90 degrees, it might not activate as easily.
Bending leads on reed switches always cracks the glass! Buy a bunch. They are very fragile. Or don't bend the leads at all, just a jumper wire.
