I think it's a vintage Bose radio, helius.
If you want to repair it yourself mandlebrot, if it is not easily spotted visual damage or a contamination issue (clean carefully off with pure isopropyl alcohol) then get a multimeter, soldering iron, solder, braid or sucker together as the basics, hunt for a schematics and then start with some basic electronics troubleshooting and take some voltage measurements and confirm that the radio is powering up and which stages have power and then if still not obvious get an oscilloscope to trace the signal, using the working one as an example.
