Hello, just another macbook pro standing between a landfill and a future of usefulness.
Laptop history: faulty discrete GPU, problem fixed by software forcing internal graphics. Worked really well for a few months with only a problem here and then not waking up from sleep.
Last week it wouldn't turn on with no chime, opened the back to have a quick look, put it back together and it turned on fine for a few days.
Now the problem came back:
No chime
No image on display and no backlight
Fans spinning at lowest rpm and heatsink building up heat after few mins
Usb mouse lighting up on one port
HDD and CD bay working
Doesn't beep without RAM
S0 voltages tested good:
PP0V7_S0
PP1V05_S0
PP1V2_S0
PP1V5_S0
PP5V_S0
PP3v3_S0
PPVCORE S0 CPU = 1.01V
PPVCORE S0 AXG =0.90V
PPVCORE S0 GPU = 0.89V
ALL_SYS_PWRGD = 3.3V
CPU_VCORE_C = 0V not sure what's this for.
PP5VSUS= 5V
GPUVCORE_EN= 3.3V
PM_ALL_GPU_PGOOD= 3.3V
GMUX_RESET_L=3.3V
PP3V3_SW_LCD = 0V
DP_MUX_EN = 3.3V
I've heard of someone with similar symptoms could get the chime back by removing the GPU resistors R8911/R8910. Not sure if he got the machine actually back to work in the end but I wanted to check more voltages before taking out the soldering iron.
Anyone know of any control voltages that could make the faulty GPU abort the start up process?
Thanks a lot in advance,
Happy new year!
Alex
