Here are pics of the display board as close as I can get with my current lens. Lighting issues unfortunately make most of markings unreadable, but below I've pasted my notes with almost all the chip designations and some tests of voltage levels. Markings that are missing are the surface mount caps and the two SOIC-16 chips: those are actually entirely blank on the top, with no signs even of markings being removed.
Vout = output voltage
Display board: MS-D3 / REV:170316 / Designed By Lys
- Mainboard side CN7:
- 1=Vout; 2=GND (frame/output); 3=Vout - 10 V
- CN2: 1:`GND`, 2:`-V`, 3:`I+`
- CN1: pins 1,2,3,4; control inputs?
- LED1,LED2: SM320561D3B 3-digit 7-segment + decimal displays
- U1,U4 (SOIC-16): no label; 3-digit display controller?
- U2,U3 (3-pin + tab): AMS1117 3.3V XJS68; voltage regulators?
- Pin 1 connected to CN2 `GND`
- C2,C4: ?,?
- E2,E3 (upper electrolytic caps): 100 μF 16 V
- E1,E4 (lower electrolytic caps): 100 μF 16 V
- RV1, RV2: 202 (2000 Ω) trim pots
- BD1,BD2 (4-pin): `+`/`-` on top, `MB6S` on bottom
- C1,R1,R2,R3: ?,472,102,102
- C3,R4,R5,R6: ?,333,333,472
- J2,J1 (back): both open
- Measurements relative to CN2 `GND`:
- CN2
- `GND` considered 0 V here, but -Vout on mainboard
- `-V` is inverse of Vout (3.5 V Vout = -3.5V `-V`) (mainboard GND)
- `I+` is -10 V w/Vout=0, see CN7 above
- U2 1,2,3,tab: 0, 3.28, 7.82, 3.28 V
- U3 1,2,3,tab: 0, 3,28, 7.91, 3.28 V
