works, some fucked up intermittent must have been driving me crazy, and the transistor might be bad too
lesson: don't take too much from confidence or experiences to try to rule out factors in old gear, its utterly chaotic as to what you will run into.
also get a long cord, I was fucking turning the unit so I can't look at the panel meter when im testing it because the cord on my work bench is too short, it was probobly working and not working as I pushed broken contact point on reference circuit, so you won't get a good glue on that low draw thing.
I used to paint the entire trace of a PCB with solder till somewhere on the forum I started reading too much about peoples experiences and I stopped doing it, turns out it would have prevented this problem.. try not to listen to the lucky gamblers and cover all points in old equipment if you want to take it easy.. I read about reliable solder joints so many times I was utterly ruling it out
I am a little dyslexic so I think I was getting different readings on positive and negative rails when I was measuring them.. probobly was measuring the correct points but the voltage was randomly changing because it was a high resistance put in a low current draw trace that was making shit jump around (normally on a normal rail this kind of problem would probobly open itself).. got confused C12 and C13 many times.
the trace measured at times 50 ohms, 10k ohms, 1 meg, 10 meg (seemed to change each time, jumping around somewhat randomly). now reads correctly 0 ohms with remelt and added solder
