Author Topic: BK 1743 power supply coarse V pot  (Read 909 times)
Offline ledtesterTopic starter
« on: June 28, 2019, 07:06:03 pm »
Hi all,
I picked up a BK 1743 power supply for $5. It's missing the coarse voltage control pot (VR1).
Does anyone have a schematic or an idea of what it should be? All of the other front pots are B25K, so I guess it stands to reason that it should also be that value  :-//
Offline coromonadalix
Re: BK 1743 power supply coarse V pot
« Reply #1 on: June 29, 2019, 02:47:36 pm »
I would try it with the same value B25k  ......  do a listing of the ic's in it, try to find the main regulator ic if there is,  it maybe build around op amps too
An user manual,   no schematics :(
https://cdn.testequity.com/documents/pdf/bk/1743B_manual.pdf
« Last Edit: June 29, 2019, 02:50:31 pm by coromonadalix »
« Reply #2 on: July 02, 2019, 08:23:49 pm »
While I wait for a B25K pot I hooked up a 15K resistor and a 10K pot. Was able to adjust the output voltage from 0 to about 12.7V so I think 25K R is the right value.
The only ICs on the board are a CA324E and a CA723CE - so basically an LM324 op-amp and the classic 723 voltage regulator.
Offline Ordinaryman1971
« Reply #3 on: May 09, 2020, 01:26:33 am »
Just to confirm, it is 25k pot. I’ve just opened mine up.
The following users thanked this post: ledtester
Online mawyatt
« Reply #4 on: May 09, 2020, 01:17:06 pm »
If the pot is used as a proper pot (3 effective wire) rather than a variable resistor (2 effective wire) a simple solution to get you back up and running until the proper 25K pot arrives is get whatever pot you have on-hand that is higher in resistance (say 50K or 100K) and place a parallel fixed resistor (50K or 33K) so paralleled result is 25K. This usually works well when used as a voltage divider (proper pot use), but also when the pot is used as a variable resistor (the knob position relative to output is non-linear tho).
Best,
Mike
~Wyatt Labs by Mike~
