Hi guys I got an used Bk Presicion 2120B which seems not to adjust the focus and when i try to calibrate don't show me the usual trace,I added some pictures of the screen maybe someone can give me a hand to fix it,I got the schematics from the web but seems to be incomplete specially on adjustments procedure.
I got skill on electronics but never work before with an oscilloscope and i don't wanna mess with the adjustments without knowing what to do or how to do it,
Pic 1 shows a dot pushing the trigger XY push button but see the dot is not rounded its looks square,pic number 2 show not the line as usual when you set it up and pic 3 shows the way it show when I try to calibrate CH1 with 2 V p-p calibration port.
I will appreciate your help by the way i got the 144 volts on P801 pin 7 and the 5 ans the 12 volts on that connector.
