Author Topic: BK 2190 scope(not A, not B, not E, etc) Service info request  (Read 615 times)
Offline watchmakerTopic starter
  • Self Study in EE
    • Precision Timepiece Restoration and Service
« on: November 13, 2023, 08:46:03 pm »
I took a flyer on this scope.  Channel 1 works perfectly, channel 2 is highly attenuated.  I switched the outputs from the channel 2 attenuator to the channel 1 vert amp and it is still highly attenuated.
So I am kind of confident it is on the attenuator board.  Which in this case handles both channel 1 and channel 2 attenuators.
I can easily get to testpoints to follow the signal with my good scope and I would like to get this up and running.  There IS a CA3127E IC for each attenuator and a couple discrete transistors. can't see for certain.  Just got a pair of RCA branded ICs just in case that is where it is.  Cheap enough.
I thought it would be a Kenwood, but it looks like not.  There is NO country of origin other than BK.  Did write BK.
Does anyone have any service info on this scope?  I would like to know the adjustments that will be needed.
Regards,
Dewey
Regards,
Dewey
Offline bdunham7
Re: BK 2190 scope(not A, not B, not E, etc) Service info request
« Reply #1 on: November 13, 2023, 09:10:15 pm »
If it is the one I'm thinking of, it is a Kikusui.
I haven't reviewed these manuals, but have a look and see if they fit.
The following users thanked this post: watchmaker
  • Self Study in EE
« Reply #2 on: November 13, 2023, 09:16:34 pm »
Damn.  That is IT!!!  Thank you.
BTW, how do I contribute $$ to run this site?  SEarched last week and found no clues.
Regards,
Dewey
Regards,
Dewey
Offline bdunham7
« Reply #3 on: November 13, 2023, 09:36:35 pm »
https://www.eevblog.com/donations/
Or you can buy something from the EEVBlog store or an EEVBlog multimeter from Amazon.
  • Self Study in EE
« Reply #4 on: November 13, 2023, 10:03:07 pm »
Just did. Thanks for this forum.
Regards,
Dewey
Regards,
Dewey
