Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
BK Precision 1762 power supply Voltage adjustments
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: BK Precision 1762 power supply Voltage adjustments (Read 569 times)
patrick richardson
Newbie
Country:
on:
May 18, 2023, 04:44:35 pm »
I've got a BK Precision 1762 power supply. If you've used one, the coarse adjust is way too coarse and the fine adjust is way too fine. A multiturn coarse adjustment would have been nice...
I increased the resistor in parallel with the fine adjust pot R68 from 2.7k to 4.7k and it gives a little more range on the fine adjust, but starts being nonlinear at the upper end. Going higher than 4.7k gets too non-linear. I can't find schematics (i asked BK and done searches) or a tech manual.
It looks like the board mount control pots are 25k, so replacing them with a multi-turn isn't likely.
Logged
coromonadalix
Super Contributor
Country:
Re: BK Precision 1762 power supply Voltage adjustments
Reply #1 on:
May 18, 2023, 09:47:54 pm »
if the main pots are 25k, its not a problem to find ones, sure theyll cost a bit, but youll get the control you need, ive done the same thing on my kepco ate psu 1 pot for Volts 1pot for Current no fine
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
