Quote from: onlooker on Yesterday at 12:03:37 PM
1). Bf = 5 to 200 for Q407 and Q408 has no significant impact on the performance of the output stage...
I am still confused on how you came to this conclusion, it looks like you hard coded the model to have a Bf = 5 for PNP and Bf = 20 for NPN. Did you change the Bf value in the model and compare results?
Bf = 5 for Q407 and Bf = 20 for Q408 were using the numbers you provided; Bf=200 was the datasheet number you or some other earlier poster quoted. I did tested the setup using Bf=5 and up for both transistors (and also varied values of other components). The voltage gain remained about 37.
This is no surprise so long as the open loop gain is much larger than 37; Theoretically, for any Bf>0 (say 0.1 or 0.5) for Q408, the open loop gain can be infinite if the collector CC sink can be assumed ideal. Then, these are just DC analysis that may be helpful for get your 0V trace back if my quick simulation was correct.
The much more critical things are the value drifts of the resistors in the feedback loop.
Are you referring to the resistor values I highlighted yellow in my table, or are you just simply stating the correct resistor values are critical? I still haven't pulled the resistors from the circuit to confirm they are bad yet.
The main feedback is through R415 in this part of schematics. Then, many other things can go wrong including the transistors you took out.
But, the 1st thing to do should be to determine if the problem is in this area by simply checking the voltage on Vin and Y+ on the schematics I showed (with auto trig on, no input on BNC and varying V pos,...). To be safe, you may clip the leads of your DMM in place with hands off.
2). The proper Vin range is ~[2,5.5] V
This is necessarily the proper Vin on my scope?
Vin is the test point marked on the schematics in my early post. [2,5.5] V is the simulation findings for having a linear Y+. It is pretty stable when varying Bf and other things.
In any case, it can be served as a reference range for you, even if your scope has a range that did not fall exactly on it.
If I were doing the repair, I probably would not take out all the parts without checking these reference operating voltages first.
Unfortunately ...
Then, hope for the best. Be gentle with the pads and traces on "older" PCBs.
