Hello,
I was doing some simple measurement when the display of my sds2104x plus got scrambled. I think it did happen in the past and rebooting the unit was enough to recover but today this is not the case, see the initial boot, I tried several times and at some point the siglent logo was ok and then the display got scrambled. It could be a software issue because SCPI is still working. I tried *RST and REC:FDEF but this does not fix the issue.
What do you think ? is there other things I should try ?
