Author Topic: Socket identification required  (Read 1205 times)
Online JarekTopic starter
« on: December 14, 2023, 02:04:36 pm »
What kind of socket is this?
Where can I buy this ?
« Last Edit: December 14, 2023, 02:06:51 pm by Jarek »
Offline Swake
Re: Socket identification required
« Reply #1 on: December 15, 2023, 03:53:27 pm »
Those pics only show the back of the connector. What does it connect to what?
When it fits stop using the hammer
« Reply #2 on: December 15, 2023, 09:24:04 pm »
Socked is in the sdr Radio Flex.
Offline coromonadalix
« Reply #3 on: December 15, 2023, 09:33:26 pm »
have you sent a mail to the company about the part ?
« Reply #4 on: December 15, 2023, 10:00:07 pm »
Not yet, but I suspect they will want me to send it to them for repair.
In my case, shipping costs will be around $400 both ways.
Offline Jwillis
« Reply #5 on: December 15, 2023, 10:24:31 pm »
It's a FPC connector. As you can see it has 6 position then 10 blank and then 14 position. So a 30 position with 10 positions omitted. Probably proprietary. If the socket needs replacing then see what the pin pitch is. You might be able to replace with a 30 pin FPC and ground the 10 positions not used.
Offline Swake
« Reply #6 on: December 16, 2023, 08:59:13 am »
I only see 3 empty positions between the 6 and 14 wired. That makes it 23, which seems a weird number but is absolutely available. If you search for "fpc connector 23pin" you'll find plenty.
When buying the connector, ensure you select the correct contact position, top or bottom.
Offline Swake
« Reply #7 on: December 16, 2023, 09:01:40 am »
« Reply #8 on: December 17, 2023, 11:42:25 pm »
Hello everyone
Thank you very much for your suggestions.
Unfortunately I need the original socket.  :(
