Hi all,
A colleague just handed me today this 8 year old defective TV / monitor for me to have a look at : Blaupunkt model B32FA112BK / BLA-32
Only a quick look to see if I can find something simple and cheap... if not, in the trash. Well, he allowed me to keep it so I can salvage the board and ditch the rest...
I know ZERO about TV / monitors, never had to work on one. So I thought I would ask for some help...
Story : TV is 8 years old. Used by his son strictly as a monitor, to connect to his game console.
Kid said that the monitor would lose picture after a while. Then he would turn it off, and power it up again and often the picture would come back, and then disappear again after a little while playing the console.
Well, that was a year ago at least, then he left the TV alone.
Today, a year later : what I find is that the TV powers up, and I can navigate the menus. So the PSU and digital stuff must be working I guess.
When navigating the menus, the picture is just fine, zero issue, so the LCD panel iself is fine (branded Samsung LT A320AP33 )
The problem I found is that when I connect a signal to the VGA input (kid I guess used HDMI for his console ?? But I have only VGA stuff here sorry), I get no picture, just a " No signal " error message on the screen. Yes, I did select 10 times the VGA input in the menus... but to no available.
The VGA connector likely saw zero use in the entire life of the monitor, so unlikely to be a cracked joint on the connector pins. Checked anyway, all joints are just fine, like new. Those on the two HDMI inputs are too.
So I guess the problem must be that it fails to display ANY signal, whatever the input you use... so the connectors and their joints are ruled out. It must be a problem with whatever circuitry is in charge of switching from one source to the other.
Problem : from what I can see, there is no external switch for me to probe / investigate.. as you can see on the pictures, it's an extremely integrated design : single board design (a small one at that) and a single chip design : A BGA chip hiding under its glued heatsink, surrounded by a Winbond DD3 SDRAM chip and a Winbond 32Mbits Flash serial chip, and that's about it !
All the traces coming from the various input connectors, go straight into the mysterious BGA chip... That chip then contains both the MCU and the analog stuff to handle all the inputs, and also drives the LCD panel itself, via 5 twisted pairs. So, somehow the processor and display part of it still work fine since the menus work fine... but the input multiplexer stuff is kaput.
Well that's my conclusion from knowing nothing about these things, and spending an hour on it.
What do you think, am I right ?
Is that a common / plausible fault, in which case it's not repairable ?
Or maybe with some luck, it's a power supply problem ? Maybe the input stuff in that BGA chip uses its own dedicated power supply rail, and it's faulty ? That would be too good to be true. I couldn't find a service manual for this device, so don't know any detail about the design of this thing.
Power supply wise, there is the mains switching PSU, then on the secondary side, there is another local small 8 pin switch mode step down converter, ref. FR9886.
Maybe there are a few dodgy solder balls under the BGA, and I could try reflowing it ? Nothing to lose so.... But my shitty hot air station will never manage to heat up that big chip, especially with its heat sink mounted on it ! So no joy.
So basically, from what I see, I would say the BGA chip is faulty and there is nothing I can do about it, so the TV is good for scrap.
What do you people say, you there, no, YOU... the one on the left, third trow, who knows these things inside out ! Tell me your thoughts please !
Hopeless as I fear, or still hope for a faulty local power supply or some random tiny passive component surrounding that BGA chip ?
I could use the markings and labels on the PCB to see if I can find a schematic for it ? Or maybe buy the whole board altogether ? Maybe it was used in many different TV, various brands, and is easy to find and affordable... who knows.
Regards,
Vince
