I came across an old tube radio from around 1949 that I would like to restore and give a second live to.
It is a Blaupunkt US4 in very good optical condition.
I was thinking of the following:
Repurpose UCH 11 since I will not be needing the oscillator / AM radio part.
Add a suitable transformer like Elma TT IZ 63 (230V primary, 2x115V -> 230V secondary, 65VA).
Add a Raspberry Pi to act as media player with line input + WLAN / Bluetooth / Airplay connectivity.
Apart from of course replacing all the caps, cleaning the sockets, checking all parts would you rather:
A: Install an isolation transformer + suitable PSU for the RasPi and decouple the audio signal with a separate audio transformer.
B: Redo the whole power section, add a suitable transformer with multiple voltages for heaters, grids, anodes etc.
C:
Apart from a first visual inspection nothing else was done. I do not know of the state the NTC and power regulator (UB10000 / U2410PL) are in, but let’s assume at least the NTC is done for after all those years.
I will not be doing these modifications on my own. There is an electrician involved, but I would like to prepare everything as thorough as possible and learn something along the way.
I have worked on a bunch of tube amplifiers before, but these were all guitar amps from a more recent period that only needed caps / resistors replaced, a couple of new tubes and some biasing or some modifications to the preamplifier section.
Sure, one could just recap this thing, not add any external accessories, keep it as close to original as possible and make sure it is plugged in the right way - but that is not what I am looking for.
Thank you and kind regards!
