I accidentally connected a laptop LiPo battery to my Agilent U8002A in reverse polarity and it went bang.
The display and controls are still working fine, but there's no output.
I took it apart to find a skid mark and a scorched ST TYN625 SCR. The magic smoke is definitely gone, so I'll order a replacement for it.
The kathode and gate through holes and pads are still intact, but the anode hole was vaporized. I think if I just bend the replacement leg over I can just solder it to the remaining copper trace rather than going into the TH.
Is there anything else I should check while I'm ordering parts?
I found this schematic on the internet, and I'm pretty sure I see the failed SCR on it. It seems to be in parallel with the output caps. What is its purpose in the circuit? Is it normal for power supplies not to have fuses or some sort of output protection?
