Author Topic: Blown fuse on LK-OP2060-003 rev: 1.2 power board  (Read 1051 times)
Offline Bumblebee001Topic starter
  • Country: mt
« on: July 03, 2019, 11:42:35 am »
Hi guys,
I have a 22" TV widescreen by DGM. Model: LTV-2261WCR - PB10PT4. It just keeps blowing one fuse after another meaning there are other components that are bad and need replacing or perhaps - better still - a change of the whole power board.
The power board carries these details: LK-OP2060-003 rev: 1.2. I saw one for sale at ShopJimmy but it is Rev 1.1.
I am no electronic genius and need guidance on how best to get this TV working again. It has been repaired twice by a local technician and the result is always a few months of use then - pop - the fuse blows again. The guy may have been economical with the repairs yet charges an arm and a leg.
I would appreciate some help from this forum.
Offline shakalnokturn
Re: Blown fuse on LK-OP2060-003 rev: 1.2 power board
« Reply #1 on: July 04, 2019, 11:21:11 pm »
If it is "only" blowing it's own power supply fuse and supposedly the TV repair place are doing their job (not just replacing the fuse), there are a few points you may want to check to start with.
Is your mains supply suitable? Bad contacts in plugs, switches, leads? Usually listening closely will give you a clue.
Is mains voltage much too low or too high? Running on a generator?
  • Country: mt
« Reply #2 on: July 06, 2019, 11:39:31 am »
There should be no issues with mains supply. Plug checked. I tested TV after replacement of fuse in another house and using another cable. Fuse blown again. It must be the board components.
Online tunk
  • Country: no
« Reply #3 on: July 07, 2019, 07:12:19 pm »
I don't know what your problem is, but if you disconnect all output from the
power board and it still blows the fuse, then the power board is the problem.
  • Country: mt
« Reply #4 on: November 14, 2022, 11:14:05 pm »
Any suggestions as to where I could source this power supply?
Regards
