Author Topic: Fluke 179 Multimeter Fuse  (Read 5140 times)
Offline Black Phoenix
  • Country: hk
Re: Fluke 179 Multimeter Fuse
« Reply #25 on: September 28, 2022, 01:17:49 am »
Therein lies the question. I suppose it would be easy to substitute a piece of copper rod for the 20mm fuse but it does seem counterintuitive. It hinges on the amount of testing that Fluke carried out... and on the rise time of the fault current. The 10kA is a maximum permissible quench current, the large fuse ought to be able to clear the fault long before that. There is a case for it in CAT II conditions though.
Yes certainly, the construction of the case is an integral part of the protection, its internal blast shield moldings, the depth of the case flanges and the ultimate impact strength of the case material are all key. Everything is ultimately sacrificial apart from the user.
Yes but let's not forget that even the equipment being a "sacrificial tool", PPEs were not present too.
Just because a Fluke can withstand a transient of thousand of volts without harm to the user, that doesn't mean I would go all in, blindly, without any PPE.
The following users thanked this post: Gyro
Offline bostonmanTopic starter
« Reply #26 on: October 17, 2022, 03:29:12 am »
The 179 manual lists the part number as 943121, but the Fluke website shows 203411. I'm uncertain if a difference exist.
Unfortunately not only does Fluke not have any in stock, but they are $21.50 each. TE has them for $7 each and are in stock.
Think I'm safe with these or does a possibility exist that they can be fake:
https://www.tequipment.net/FlukeFuses943121.html?v=0
Edit: TE lists two part numbers in their fuse selection guide. 203411 (which matches the Fluke website), but has the five pack under a different part number 203414, however, a Fluke 179 isn't listed in both part numbers implying they are different fuses (I assume it's a part number for a five pack, but the same fuse).
« Last Edit: October 17, 2022, 03:43:51 am by bostonman »
  • Country: hk
« Reply #27 on: October 17, 2022, 10:13:50 am »
The fuses sold by TE are the correct fuses, you can go with them. Te list the 179 in the description of the item.
« Reply #28 on: October 17, 2022, 12:09:29 pm »
Do you think the five pack and the single ones are the same even though they are different part numbers and don't list the 179 in the description for both?
  • Country: hk
« Reply #29 on: October 17, 2022, 01:52:03 pm »
But of course. The difference between item no are basically database entries.
They can't be the same, so a unit have a part no. A box with 5 units is another part no.
« Reply #30 on: October 17, 2022, 01:55:24 pm »
That's what I assumed, but the list of meter model numbers isn't in the quantity five part number description implying they are different fuses.
Obviously I understood they are the same fuse, but they are confusing the viewer by not listing the 179 in both part numbers.
Offline Gyro
« Reply #31 on: November 13, 2022, 08:57:32 pm »
On a whim, I revisited this the other day - this being, the early Fluke approach of fitting series 600mA 20mm x 5mm ceramic fuses (250V, sand filled, 1.5kA breaking) in series with a standard Fluke large 3A 600V 10kA meter fuse on the mA current ranges. In my case on a Fluke 25.
The cost advantage of only having to replace a cheap sacrificial 20mm fuse most of the time is clear but the discussion was centering around whether this early approach was safe, whether the 20mm fuse could explode or arc over under extreme fault currents, and whether it was actually safer to replace the 20mm fuse with a piece of copper rod or whatever (probably yes).
I've now fitted a Littlefuse 230V 10kA GDT from stock, in heatshrink for extra protection, across the rear of the 20mA fuseholder. My thinking is along the lines of the GDT capturing the current if the 20mm fuse blows at mains voltage high fault current, and taking out the main 10kA fuse.
This is a very academic question, as I am not in the habit of using DMM current ranges, blowing fuses, or using DMMs on high energy circuits. I have Cat III+ stuff for that anyway. I'm certainly not going to waste the cost of the 10kA breaking fuse with some sort of high energy capacitor discharge test rig. I just wondered what others think.
The only potential fault scenario I can think of at the moment is the 20mm fuse failing to break the fault current and its arc voltage being too low to trigger the GDT.
Best Regards, Chris
Offline bastl_r
« Reply #32 on: November 14, 2022, 09:41:45 pm »
The folllowing  video  shwos what hapen when a 100000µF 700VDC capbank will be discharged on a low price Multimeter. The last one is complete without a fuse. :bullshit:
And this is what hapen when the discharge blow a Fluke fuse
The following users thanked this post: Gyro, robert.rozee
Offline Gyro
« Reply #33 on: November 14, 2022, 10:11:59 pm »
A good demonstration of arc flash - although the meters seem to fly apart too quickly to sustain a flame arc! A big shrapnel field though. Probably penetrating wounds rather than burns.
That test setup looks pretty dodgy for that amount of store energy though.  :scared:
« Last Edit: November 14, 2022, 10:17:02 pm by Gyro »
Best Regards, Chris
