Author Topic: Blue Yeti microphone Rev.7 firmware file (EEPROM; Arduino) ?  (Read 1321 times)
Offline Ivan_s_LabTopic starter
Greetings, I have a Blue Yeti with a revision 7 digital PCB with a corrupted EEPROM. Now this version of the Yeti is notorious for losing its firmware when connected to certain USB ports. Basically it uses a UAC3576B ADC which reads its firmware off a 24c128 EEPROM. Now I've had a few of these mics but they were all different revisions which use different ADCs so their firmware is not compatible with the revision 7 board. I don't have an EEPROM programmer but I do have a few Arduino boards that I can MacGyver into one. So If anyone has had this issue and still has the firmware file stored somewhere I would be very grateful if they can share it. Thank you in advance. :-+
